4 signs of bad turbos that I've personally witnessed...maybe it'll kill some paranoia, or make
Old 04-24-2002, 06:34 AM
  #21
LCP
AudiWorld Expert
LCP's Avatar
Default A 5th legitimate sign of failure:
The car feels just a little slow (almost imperceptible -- like heatsoak) in the bulk of the RPM band, but very slow past 5500-6000rpm (where one good turbo cannot compensate for the other poor-/non-performing turbo) -- it may be hard to notice below 80mph because of the brief time you are over 5500rpm below 80mph. This sign can be exhibited on the stock ECU, and may last for a couple of weeks before you have a full failure.
Old 04-24-2002, 06:37 AM
  #22
Banned
Mike@VAST's Avatar
Default new cats would fix my situation, but in your case, a denser cat would fix it. but, i'd forget the
annoyance of those codes and keep running it unless they are definitely degrading. maybe the CEL comes on with that code only after it has been set for a continued amount of time. when i set it for each side of the exhaust, it didn't turn the CEL on...but I do remember erasing them after i saw them.
mike
Old 04-24-2002, 06:38 AM
  #23
Banned
Mike@VAST's Avatar
cool!
  #24
Banned
Mike@VAST's Avatar
Default sorry....did you get a look at that inlet IC hose yet on the driver's side?
hope all is well.
Old 04-24-2002, 06:39 AM
  #25
Banned
Mike@VAST's Avatar
that's how you're supposed to react after a siren goes off
Old 04-24-2002, 06:41 AM
  #26
Elder Member
BiturboBoy_V2.0_S3--'s Avatar
Default this one then?
<center><img src="http://pictureposter.audiworld.com/13456/engine2.jpg"></center><p>
Old 04-24-2002, 06:46 AM
  #27
Senior Member
xr8edS4's Avatar
I always keep my hose in check, y0!
Old 04-24-2002, 06:52 AM
  #28
Elder Member
your hose are dirty.
Old 04-24-2002, 06:55 AM
  #29
ShutupAndHoldon's Avatar
Default How about a grinding squeal and "tons of blue smoke out the Exhaust"
BTW good post thanks
Old 04-24-2002, 07:24 AM
  #30
Banned
Mike@VAST's Avatar
yep...his hose is in a different area code right now? he should go inspect it.
Quick Reply: 4 signs of bad turbos that I've personally witnessed...maybe it'll kill some paranoia, or make
