Am I correct in presuming that to replace my clunking strut mounts, I must remove the suspension?
Still in diagnosis phase. Funny you mention the new suspension thing
I've been cruising the net looking at coilovers.
I'm going to check the shock mounts tonight to make sure they haven't come loose.
With 93k on the car, I just presume something is worn and needs replacing.
Might even cost less than that...
top nut on the piston is loose, or the load bearing washer was installed in the wrong order...either or might cost you $0 in parts to fix...just the labor.
Wait until you get your coilovers (which you're buying by the way) to install the strut mounts.
Eibach Pro Street S Coilover or Vogtland Coilovers are what I can recommend from experience.
