AMS & APR K04's Dyno results on 91 octane pump gas
Old 03-01-2003, 08:59 AM
  #11
s4what?'s Avatar
AF measured w/ O2 sensor in car or w/ wideband?
Old 03-01-2003, 09:01 AM
  #12
Member
Marin S4's Avatar
Default Exhaust probe with what looked like a 5 wire o2 sensor.....
not really sure what it was.
Old 03-01-2003, 09:03 AM
  #13
r1eater's Avatar
Default Here are my numbers...93oct pump gas/program
<center><img src="http://www.s4racing.com/data/stageIIIdynosmall.jpg"></center><p>for ref my stage 2 car got 244 on this dyno
  #14
Member
Marin S4's Avatar
Default Very different than what we are use to seeing but whats important......
is the difference between the AMS &amp; APR chips on the SAME CAR, SAME DAY, SAME DYNO
Old 03-01-2003, 09:04 AM
  #15
r1eater's Avatar
do you have an M box?
Old 03-01-2003, 09:06 AM
  #16
Junior Member
Ben@achtuning's Avatar
Default thanks Tom!
I still don't understand why Vishnu's dyno produces such low max numbers though...didn't you say a 996 turbo ran on that dyno at one time or another? Were you able to see the results from similar power outputs from other cars? Funny, I was talking to the Vishnu guys a couple weeks ago about carrying their stuff for the WRX's, heh
Old 03-01-2003, 09:08 AM
  #17
New Member
Avus's Avatar
Default your car weighs 4700 lbs?
huh?
  #18
Member
Marin S4's Avatar
Default Impossable to compair 2 different dyno's results but if you look at the....
power curve your power peaks at 5,000 RPM's
That means you still have some uptapped power in there somewhere. Power peak should be much higher on 93 octane gas.
Old 03-01-2003, 09:11 AM
  #19
Member
SMOKINA4TURBO's Avatar
Default Re: Its a 5-wire 02 sensor...
Advanced Tuning Products has a dynojet around the same area.
Vishnu's dyno reads a little lower then the dynojet but nothing too substantial.
All dyno's use 5-wire 02 sensors stuck in the tailpipe usually. I'd run as far from a place if they were tuning cars not on a wideband unit.
Old 03-01-2003, 09:13 AM
  #20
r1eater's Avatar
Default My intent was not to compare my numbers to yours..
I was putting them up to show what my car did on the our dyno.. Again I did 244 as a stage II and now I'm up to 352 thats an increase of 109hp
Quick Reply: AMS & APR K04's Dyno results on 91 octane pump gas
