Anyone with brake warning light issues? - AudiWorld Forums
Old 07-27-2009, 07:23 AM   #1
Default Anyone with brake warning light issues?
Last week while driving I got a flashing brake warning light. It went off after only a few seconds. The same thing happened again yesterday. Acccording to the manual there may be some major issue with my brakes, but that just makes no sense seeing as how my car is not raced, rarely driven and there is about a whopping 10k on the current pads. This was not a low pad warning indicator, it is the red brake light on the speedo that flashes momentarily. I have a 2000 S4 with under 67k. Anyone else ever have an issue with this before I take it in for diagnosis?
dcso30 is offline   Reply With Quote
Old 07-27-2009, 08:32 AM   #2
nimmote's Avatar
when bleeding my brakes, it did that when the fluid got low and went away when i refiled it. Maybe your fluid is a little on the low side and you hit a bump, turned hard or something to move the fluid away from the sensor? Just check the fuid incase. Hopefully it will be that easy Or you can just throw money at it, that should fix it. Good luck
nimmote is offline   Reply With Quote
Old 07-27-2009, 08:51 AM   #3
^+1
The brake light will flash like that if you're nearly bottomed out on the fluid but there's just enough left to cover up the sensor - check that fluid level and you'll know right away if that is your problem.
donromani is offline   Reply With Quote
Old 07-27-2009, 12:08 PM   #4
Check the fluid level, overfilling or underfill can be a problem. I had ghost brake warnings as well. Could also be a contact problem. My guess is that it is intermittent and will go away.
tedavis01 is offline   Reply With Quote
Old 07-28-2009, 02:23 PM   #5
ive been having that problem for about a week or 2 now, and i have all new pads with plenty of life, i figured i got some paint on a the a sensor or somthing that might not have been taped well enough when i painted my calipers, but im gona check fluid when i get home now, but i had no problems prior to painting
twv5004 is offline   Reply With Quote
Old 07-30-2009, 05:51 PM   #6
Thanks for all the responses. Gonna check the fluids tomorrow am. Called my Audi tech and ran it by him, he said that its not uncommon for B5 A4 and S4's to have the ABS control module go and that may be it. A new module is $800!!! However, there is supposedly some places that will repair your old one and warranty their work. Anyone know of such a shop should I need it?
Old 07-31-2009, 11:17 AM   #7
Its not the ABS, you can get your ABS rebuilt for much less than $800 if you need it.
MySTG3S4 is offline   Reply With Quote
Old 07-31-2009, 02:17 PM   #8
I checked my fluid levels and it is not a fluid issue. It was right on spot. How else can I rule out anything other than the module?
Old 08-05-2009, 08:41 AM   #9
When the light flashes does your ABS work when you slam hard on the brake pedal? I had exactly the same problem which turned out to be the ABS module. I found a place who reconditioned the unit for 100.00gbp It cured the problem. Good Luck mine got progressively worse until the light was flashing all the time which realy gets on your nerves and beeped everytime the ignition was turned on.
babins4 is offline   Reply With Quote
Old 08-06-2009, 05:27 AM   #10
I have yet to test it by panic breaking, but everything points to it being the module. I was able to find a couple places, thanks to the forum, that will rebuild my module and warranty their work. Thanks everybody for the help!
Thread Thread Starter Forum Replies Last Post
Audi A6 FS: 370mm Alcon / Stasis Front Big Brake Kit! Allroad BBK N'Syncro Parts For Sale 12 01-24-2017 04:46 PM
Mk1 tt overheating at idle Boosted01tt 1.8T Discussion 5 01-03-2017 06:55 PM
:: ECS Tuning :: Assembled by ECS Audi B6 A4 1.8T Quattro Brake Service Kits. ECS Tuning-Audi A4 (B6 Platform) Discussion 0 09-02-2015 12:39 PM
95 Cabriolet Power Roof Fix. stormchaser1967 Audi A5 / S5 / RS5 Coupe & Cabrio (B8) 0 09-02-2015 10:26 AM
Audi C4 2.6 Could not start aron56 Audi 100 / A6 (C4 Platform) 0 09-01-2015 01:39 AM
Tags
1998, 2005, 2007, a3, a6, a8, audi, brake, driving, light, pad, q7, s4, tt, warning
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
