Anyone ever get DTC 18048 - EEPROM error?!
Old 03-15-2008, 02:58 PM
DxC
DxC's Avatar
Default Anyone ever get DTC 18048 - EEPROM error?!
my car wont crank, i went into looking into the starter motor/ign switch but read codes first and this is what i found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
18048 - Internal Control Module: EEPROM Error
P1640 - 35-10 - - - Intermittent
i cleared the codes, and tried to start the car, but still no luck. in STFA, there doesnt seem to be much info. someone said the ECU is fried ... but i dont buy it. shouldnt the car still crank without the ECU?
i also am able to play with cruise control programs (APR code) so it is reading from the ECU still
im just looking into some easy fixes before messing with starter motor replacement. apparently i have to remove the alternator just to get to the exciter wire for the starter motor ... any other ideas?
Old 03-15-2008, 03:33 PM
mike (@home)'s Avatar
unplug the ECU and see if she cranks?
Old 03-15-2008, 04:31 PM
AudiWorld Expert
nyet's Avatar
Default car won't crank if ecu gets eeprom error
ecu is fried, or eeprom corrupted. Needs to be replaced or reflashed.
Old 03-15-2008, 05:38 PM
Banned
Mark@AutoSpeed's Avatar
incorrect, car will crank even with ECU not plugged in...
Old 03-16-2008, 09:36 AM
AudiWorld Expert
nyet's Avatar
crank as in crank or crank as in start?
Old 03-16-2008, 08:42 PM
daves4izzle::ASP 3-'s Avatar
Crank as in turn over but not start. No spark will be sent to motor without ECU AFAIK.
Old 03-16-2008, 08:43 PM
If you've ever seen an ECU flash go wrong, the car will just crank and crank but not start.
Old 03-17-2008, 01:27 PM
Tomasz@Startup's Avatar
Default I think all you need is a jump.
Battery is low.
BeauA4
12-08-2006 06:07 AM
philshort
VAG-COM Discussion
12-16-2005 05:06 AM
alfonzo312
Quattro: Turbo / Ur / Sport
06-06-2005 09:17 AM
Quick Reply: Anyone ever get DTC 18048 - EEPROM error?!
