audi s4 b5 mod pointers
Hey!
im planing a project with my old audi s4 2,7 twin turbo
i plan on runing stock pistons and cylinders
2.8 heads and 2.8 cams
rpm rods and new bearings
srm k24 hybrid turbos and upgraded intrecooler system.
any input on this setup?
and anyone know how muc modifications has to be done to the 2.8 heads to get them to fit?
do i use 2.7t gasket or 2.8 gasket?
also does anyone haveasugestion for a clutch setup that would alow me to drive it in trafic?
i have only been able 2 find drag clutches that can handle the power and i know those r useless in trafic...
apreciate any input
apreciate any input
the 2.7 and 2.8 are basically the same engine. The heads are pretty much the same, no modifications necessary other than block off the ports for air injection if you dont have it. All the valve cover gaskets, chain tensioner gaskets, cam seals cam plugs all the interchange. you want 2.7T intake gaskets since your using 2.7 intake.
bikenut
02-06-2014 04:41 PM
BlkBullitt
03-26-2009 03:13 AM
The Black Knight
07-19-2007 08:56 PM
pane2k
03-06-2007 06:23 PM
Captain Matt, I be
03-20-2006 05:57 AM
