AutoSpeed is pleased to announce RS6 Turbo Kit Performance Numbers...
Hey Guys,
We worked out the issues we had with the RS6 wastegates on the turbos and now have performance data to back our kit.
The subject vehicle is a 2001 AllRoad (aka RMcQ) with forged rods and all other intake components stock spec, no RS4 power adders. ASP manifolds, DP's and FMIC.
The following dyno plots represent 93 Octane and VP109 Unleaded Racegas Profiles.
Note a healthy K04 car running 23psi on our dyno makes apporx. 350-360whp on 93 octane.
<img src="http://www.autospeed.us/pics/RS6_93.jpg">
<img src="http://www.autospeed.us/pics/RS6_VP109.jpg">
<img src="http://www.autospeed.us/pics/rs6-3.jpg">
<img src="http://www.autospeed.us/pics/rs6-4.jpg">
Here is what's included in our kit...
[2] Factory KKK RS6 TurboChargers
[1] Set K04 Inlet Tubes
[1] MAF Housing/Hose/Clamps
[6] 630cc Fuel Injectors/Hardware
[6] Bosch Spark Plugs
[1] ECT, Clip & Oring
[1] N75 Valve
[1] Bosch MotorSport 044 Fuel Pump, Backet & Strainer
[1] Turbo Hardware Kit
[1] ASP Software 93/109/valet/kill
List Price $6995
We believe we have the most comprehensive kit on the market. Also these are the only true
"bolt-on" solution requiring absolutely no modifications to any components. The other kits require you to have your existing downpipes cut apart and have flanges re-welded on.
Our software is the most advanced as we have reprogrammed the factory routines to allow for multiple programs switchable by the end user as well as have datalogging functionality with no need for 3rd party programs.
What this means is you and your dealer have the ability to datalog the car at lightning speeds, over 45 variables @ 30times a second! You send us the logs and we can then tweak your file for perfection. The dealer can then reflash your vehicle from our webserver within minutes.
Give us a call, let's make some power!
[1] N75 Valve
List Price $6995
