BOV's...a little tip
Old 09-24-2002, 10:15 AM
  #51
wishbone's Avatar
Default Yeah I got what he was saying with idle and non-boost applications..
I suppose what I'm looking for from him is what you just said... it will run rich, but it's not enough to matter.. I'm still curious if he's still using the electronic control system for them...
Old 09-24-2002, 10:17 AM
  #52
AudiWorld Expert
nyet's Avatar
Default [edit] but now the extra pressure in the INTAKE system will prevent MORE air from passing the MAF
.. further up the line.
Think of it this way, once the BPV dumps air back into the intake, the VACUUM is less after the MAF, so less air will pass the MAF.
[edit]
in fact, if what Don says is true, and if under HIGH BOOST applications there is enough BPV pressure to blow intake hoses, presumably there is NO longer vacuum after the MAF, meaning air will flow back PAST the MAF backwards, further screwing up the MAF readings.
Old 09-24-2002, 10:23 AM
  #53
Member
zapco98's Avatar
Default Naw, the car runs rich in essense because say for example you take your Forge valve
and disconnect the part that goes back into the intake, and plug that hole - now the vacuum is holding the valve open a bit, so its causing the air to go right into the atmosphere. The car begins to run rough because the system is no longer 'pressurized'... so to circumvent such issues, a stiff/adjustable spring will allow it to stay closed under idle vacuum, causing the system to stay pressurized, and the ECU should adapt accordingly - otherwise you're just having arrant amounts of air fluxuating out of the valve. For instance, if you take your forge valve, and unplug that one end - and put a stiff spring in the forge valve, and used washer's to help adjust when the valve opens (under how many hG's of vacuum) you could make the forge's work as a BOV - the downside to this as some of us were discussing last night, is unless you use a very stiff spring - and use washers or what not to compress the spring some more, you lose some piston travel on release which may or may not be bad. It still opens more than a stock BPV...
The car will run correctly though - a simple test is to open one end of your valve, and tape the end closed, you will notice that your idle will be perfect (do NOT make boost while you have the tape in place).
Old 09-24-2002, 10:24 AM
  #54
AudiWorld Expert
nyet's Avatar
ah got it.
Old 09-24-2002, 10:49 AM
  #55
Jack Wang's Avatar
Default Oh, Ok, so for 1.8T the BOV will be where the BPV is..am I thinking right?
The reason I ask is because I have seen 1.8Ts with BOVs mounted at different locations, but no where near or replacing the BPV..
Thanks.
Jack
99.5 1.8QT
Old 09-24-2002, 11:12 AM
  #56
Member
wnut's Avatar
Default there's about 3 ways to mount a bov on a 1.8t
it depends on which style bov your running.
for styles like the greddy typeS or turboXS type H-25 - they simply plug into where ur bpv is.
for styles like the hks ssq, and "other" turboXS one (the one on the right of don's post) - you need to get a little more creative and get a adaptor or a custom flange. you could also mount these on ur ic return hose (you'll need a custom pipe with the flange welded on), this will run in conjunction with your bpv.
email me if your interested in the second style with the hks, i believe we have a few kits still on the shelf.
-w
Old 09-24-2002, 11:38 AM
  #57
wishbone's Avatar
Default Well...
A couple of things if I understand what you're saying. When it dumps back into the system it's not getting metered again. It's all behind the MAF at this point. Also because the BPVs are open (vacuum in manifold) it just continue to circulate until the throttle plate opens again. If for some strange reason the air did flow back out the intake (maybe the BPVs are malfunctioning?) the MAF is capable of reading return air flow. What it does with these reading I do not fully understand, but it is capable of it.
Old 09-24-2002, 12:06 PM
  #58
Rest In Peace
markbradford's Avatar
Default I was wondering that too. Must run rich during shifts no? DOn, would you recommend this for......
a street car?
Old 09-24-2002, 12:55 PM
  #59
Junior Member
(not a) $leeperA4's Avatar
Default I WANT BLOW OFF!!!!.....
i have a A4 1.8tqm w/ stock K03 and a Bailey's BPV, WHAT DO I NEED TO DO TO GET A BOV?
Old 09-24-2002, 01:52 PM
  #60
WJM
WJM's Avatar
Default Don what about "engine wash"
The Audis run extra fuel (rich) to lower the exhaust gas temps, removing air and causing the car to run richer has been known to generate engine wash (washing the cylinder sidewalls with fuel) Are you saying that our cars run lean enough for that not to happen? I know Supras and other turbo charged cars have been prown to that when their boost is vented to atmosphere.
Just curious
-Will
Quick Reply: BOV's...a little tip
