Can someone decifer a DTC for me, pleez?
Old 05-01-2001, 01:39 PM
LosGatosS4's Avatar
Default Can someone decifer a DTC for me, pleez?
In Control Module 45 - Int. Monitor:
Fault Code: 01382 - Alarm via Anti-theft sensor - front left 35-00
I know my alarm has been set off a few times recently because the sunroof was left open without shutting off the interior motion sensor - is that the cause of this DTC or is something wrong with my alarm?
Old 05-01-2001, 02:01 PM
rao
rao's Avatar
That's exactly what it means
Old 05-01-2001, 02:11 PM
funkadelic's Avatar
Default here ya go
wait a pain in the *** to find it but....straight from the bentley cd:
<img src="http://www.funkadelic.org/i/aw/dtc/01382.gif" width=605 height=274>
Old 05-01-2001, 02:19 PM
LosGatosS4's Avatar
Default THANKS!!!! looks like I need to get the CD...
any chance I could trouble you to please snap page 01-117 - Adapt sensitivity of sensors ???
I'm trying to adjust the sensitivity of the Interior Monitor but I need the codes/proceedure.
Thanks again!
Old 05-01-2001, 02:56 PM
malcho's Avatar
I can do that for you but, later on tonight when I get home....
Old 05-01-2001, 02:57 PM
funkadelic's Avatar
i'm trying out the sensitivity adaption right now...will post when i figure it out
Old 05-01-2001, 03:17 PM
funkadelic's Avatar
Default ok here's how to do it w/vag-com
1) go into Select Control Module
2) select 45 - Int. Monitor
3) under Advanced Functions, select "Adaptation - 10"
4) Read channel 01
5) enter a value between 50-100 (it should be 100 by default) for the sensitivity of the ultra-sound sensors
6) Save...you're all done!
I tried it at 75 with all my windows slightly cracked, but my alarm sounded after a gusk of wind blew by. Even with the sensitivity turned down further, the sensors may be too close to the windows and wind will trip them (maybe that's why the override switch is there). Lemme know what setting you end up using.
<font color="white">interior motion sensor adjustment</font>
Old 05-01-2001, 03:22 PM
LosGatosS4's Avatar
AWESOME - THANKS!! I'll give it a try tonight and let you know... probably 50 tho
Old 05-01-2001, 04:56 PM
New Member
Deez's Avatar
Someone should make this a FAQ/Tech doc
Old 05-01-2001, 05:00 PM
funkadelic's Avatar
yeah, guess i can do a short write-up
Quick Reply: Can someone decifer a DTC for me, pleez?
