Changing the spark plugs (warning: many pics!)
Old 06-04-2001, 07:25 AM
  #11
2faS4u2pass's Avatar
Default Oooohhhh...sounds interesting guys but let Ferris mend his thumb first otherwise...
his 0-60 and 1/4 mile runs will be .008's slower than normal........
Good job on the <i>insta-pics</i> (install pics), I keep missing all these fun stuff you guys are doing lately
Old 06-04-2001, 07:31 AM
  #12
Junior Member
S4er's Avatar
Please let me know where and what to get, TIA
Old 06-04-2001, 07:32 AM
  #13
The R's Avatar
Hmm.........Something to consider.
Old 06-04-2001, 07:36 AM
  #14
Ferris TMK's Avatar
Default Re: Please let me know where and what to get, TIA
<ul><li><a href="http://www.machvw.com">MachVW</a></li></ul>
Old 06-04-2001, 07:49 AM
  #15
Junior Member
DrSmile's Avatar
Default Turbos don't like irridium / platinum
Speaking from experience, although the S4 may be an exception... If you run 1+ bar I would definitely go with plain ol plugs.
Old 06-04-2001, 07:51 AM
  #16
New Member
MingS4's Avatar
New Iridium vs. old oem. Who knows, new oem may have given same results? IMHO.
Old 06-04-2001, 08:01 AM
  #17
Ferris TMK's Avatar
Default Stock is platinum...
I actually thought the same thing about Platinum and was surprised to see them installed.
Copper's melting point is 1981 degrees F.
Iridium's melting point is 4449 degrees F.
Platinum's melting point is 3224 degrees F.
Copper's Tensile strength is 20,000 PSI.
Iridium's Tensile Strength is 160,000 PSI.
Platinum's Tensile Strength is 20,000 PSI.
I think the issue people were having lie with the Bosch Platinum's and I think that's why Audi went NGK..
Old 06-04-2001, 08:04 AM
  #18
Ferris TMK's Avatar
Default Yes
I didn't claim it to be better, like I said we had no hard data. Science proves it takes less power produce a good enough arc w/ iridium so you could theoretically run larger gaps. However with out the data on the coil pack it's all theory. Do what you want I'm just presenting another option
Old 06-04-2001, 08:08 AM
  #19
Junior Member
DrSmile's Avatar
Default Re: Stock is platinum...
I have run NGK platinums in my DSM and without fail the car will start to miss past 18psi (1.2 bar). And yes I realize stock is platinum but I think that's more of a service issue for Audi than anything else seeing how much of a pita it is to get at the plugs.
Old 06-04-2001, 08:14 AM
  #20
///Mike@Boston Audi's Avatar
Default Ok, I have a few questions - what do different gap sizes and heat ranges provide? what's the
optimum for both on our cars? would there be any benefit to changing the gap or the heat range for stock vehicles? What about chipped cars?
Quick Reply: Changing the spark plugs (warning: many pics!)
