Check engine light on. Fault code P1475; What does this mean?
I had the light come on late yesterday afternoon. I was by an Autozone so I had them pull the code up with whatever scanner they had (it was free). The code said P1475. Any ideas what this is and how to fix it? Is the car ok to drive in the mean time? Thanks.
Leak detection pump open. It sounds like a vaccum pump that pulls
a vaccum on the tank and evap system to detect leaks. I've never diagnosed an evap system on a turbo car, but naturally aspirated cars use engine vaccum to pull a vaccum on the system to check for leaks,so it makes sense that the s4 would use a vaccum pump. if it were me, i would find the pump, make sure it has 12v+ and if it does replace the pump. if it doesn't have voltage, look for a blown fuse.
