Creaking noise from rear like a Bad CV joint?!?
I noticed when I go from a stop to make a turn that metal ball sounding creeking CV joint going bad noise but from the rear of the car.
could be a failing wheel bearing or possibly a broken coil spring..
..take a peek underneath; usually when CVs fail it is because the boot became torn, all grease came out and dirt infiltrated the joint
i was hearing noises and it turned out to be a broken coil spring...if the coil is your prob, i have an extra rear ill give you
KillA6
01-13-2009 10:12 AM
blur2u
12-06-2006 11:39 AM
clinton c
01-20-2005 05:42 PM
