Did some air intake modifications and VAG testing - est. 15-20 hp gain (LONG)
#21
Check out Tory's post of the initial prototype below, my hole is in the same spot.
<center><img src="http://home.pacbell.net/tmblue/images/airbox1.JPG"></center><p>
#23
MArk is the S-flow ITG filter from the G60 VW kit, thus the G60 extension?
Can't find the supplied ITG filter from the S-flow kit on the ITG site, is it custom sized?
Thanks bro
Tory
Thanks bro
Tory
#25
we chose the G60 filter because the staging element is better...
suited to a high heat environment like the S4 and it has been proven in a forced induction application ...the manufacturer recommended this type of staged foam for this application!
#26
Good catch, I noticed this awhile back too - however the rating is for N/A cars,
for forced induction you multiply that by some factor. K&N says the same thing for their filters when they give a HP rating. I don't remember what the factor is, but a 300hp filter would be good for something over 400hp in our turbo car.
#27
That rating is for a NA application, we had that filter on Blitz car when he ran high 12's...
he was probably making 380hp+ at that time...the filter darin used is the same exact filter(velocity stacks etc are the same) with a cylindrical shape versus a taper-the cylindrical shape offers a larger surface area but, the large majority of the airflow comes right at the base of the velocity stack which in both applications is the same!
#28
that's odd. I got 279 g/s pretty consistant from about 4k to 6500k using the stock airbox and
<center><img src="http://pictureposter.audiworld.com/21907/maf.jpg"></center><p>filter. it was 80 degrees out when I logged
this. I'll try it again and see what results
i get once my VAG COM cable gets fixed.
#30
so do you recommend cutting the bottom of the air box to suck more air to increase hp?
i have a s-flo so is our setup optimal? or will we benefit from the "hole" in the bottom mod?
if so can you shoot some picture of your setup?
and a little mini how to?
