Has anyone O-ringed their block? if so, what gasket did you use? and is it a good idea?
Old 04-24-2008, 10:57 AM
DxC
DxC's Avatar
Default Has anyone O-ringed their block? if so, what gasket did you use? and is it a good idea?
im thinking its a good idea if i want to be boosting 28psi.
ive seen a lot of BMW turbo builds doing this and they're running much less boost ... necessary or overkill?
Old 04-24-2008, 11:10 AM
Member
my2000apb  MEGABOOST's Avatar
Default Simp did on the wms black beast, u wont need it with rs6 snails, def overkill, i would think >
only need it on 35+ psi
Old 04-24-2008, 11:11 AM
Member
whats your aim name?
Old 04-24-2008, 12:26 PM
DxC
DxC's Avatar
nogaro smurf
Old 04-24-2008, 01:04 PM
Snow Trooper's Avatar
Not needed with that boost level or anything close to it
Old 04-24-2008, 01:10 PM
@wesome's Avatar
fine.. i'll ask... what is "O-ringing" a block?
Old 04-24-2008, 03:48 PM
audidweeb's Avatar
I think he meant sleeve.
Old 04-24-2008, 04:03 PM
Default No, o-ringed. Its the act of using a SS o-ring to aid in sealing on high boost or high CR engines.
In laymens terms... A groove is machined into the circumference of each cylinder and then a stainless steel wire that fits in the groove is laid in place, sticking up above the deck of the block a very small amount.
Old 04-24-2008, 04:45 PM
Hal_TT::CBP's Avatar
With Jared. Overkill. 35psi maybe, but you'd likely float the heads at that pressure on our cars.
Old 04-24-2008, 06:57 PM
@wesome's Avatar
Oh sick!
Quick Reply: Has anyone O-ringed their block? if so, what gasket did you use? and is it a good idea?
