help!!! massive boost leak
I did the pressure test, but could not find the leak. I check all the host and it seem to be fine. I even check TBB and change out the old BPV to new one. for some reason it still a leak some where and my car won't hold boots at full throttle. What else can be done beside take it to a shop ?
If you pressure tested and didn't hear anything, there is no massive boost leak.
Maybe your problem is not a leak... Bad N75? Software problem (limp mode)? Have you checked the codes or logged the car? Those will tell you a lot.
then how do I keep get boost bounce on and off from 21 to 10 psi ?
when I pressure test. all the air is escape to some where because my air tank keep getting empty. I remember when I did the pressure test previously, air stay in the system
I test it again, but this time not from the y pipe, I blow it in by the bipipe
but still can't locate it. I will have to get a smoke machine. because air don't even hold from the bipipe
ixi
08-17-2009 06:45 AM
svenson69
10
10-31-2007 03:07 PM
