does anybody know to install a manual boost controllerfor the B5 S4?
Seriously, a step by step guide is what I would love to see. The illustrations are good....
but don't make sense if you don't know what line goes to where in the first place.
I have yet to see a good tech article detailing the install along with pictures of each step.
Re: does anybody know to install a manual boost controllerfor the B5 S4?
if anybody does have instruction, can they explain in great detail. i am assuming that it is a pain in the butt.
for vast mbc, simply
pop off the bottom hose to the n75, put it on the bottom of the mbc. take the right side hose (driver side) off the n75 and put it on the side of the mbc.
leave the 3rd hose alone (pass side), and leave the n75 plugged in... done.
for mbc only though. basically same for parallel, but put in vacuum T's and leave the n75 fully hooked up.
it's not a PITA. here's a pic from the Vast site
<center><img src="http://www.vastperformance.com/images/fpr_mbc_instructions_8_TEXT_web.JPG"></center><p>as the_suN said, if MBC only, take the blue and green from the N75 and put onto the MBC.
if MBC in parallel, put a 'T' in the blue and green lines connected to the N75 and connect the 'T's to the MBC.
if you don't know the difference between MBC only and parallel, then STFA.
It's really not that hard. Look at pics and copy visual image...
These all demonstrate a "parallel" configuration. To get "MBC only" just delete the N75 from the loop (one line from MBC to wastegates and the other line from MBC to turbo)...
<img src="http://i146.photobucket.com/albums/r273/swankadelic/MBC/MBC2.jpg">
<img src="http://i146.photobucket.com/albums/r273/swankadelic/MBC/MBC3.jpg">
<img src="http://i146.photobucket.com/albums/r273/swankadelic/MBC/MBC1.jpg">
