Does the S4 have 16 psi of boost?
Guest
Posts: n/a
According to R&T the S4 has 16 psi of boost. I'm not a turbo expert but that seems awfully high.
R&T seems to have many errors on the S4's specs including the engine block and trim so I was wondering if the boost was wrong also.
This feeling of waiting for my S4 is unbearable. I've been carrying around every piece of literature (Euro/US brochures, magagine articles etc.) that I have on the S4 everywhere I go (work, class, restaraunts, bathroom). Anybody else?
Drew
Drew
Guest
Posts: n/a
Not 100% sure, but I think each turbo is running about 7lbs boost. (more)
You cannot add the two up to get 14 lbs, either. There is 7lbs of boost pressure in each cylinder bank.
The 1.8T uses the K03 turbo, in stock form the turbo is producing a maximum of about 7 or 8 psi. Doubling that to about 14.5 psi on 1.8T (producing around 200hp) is pretty much known to be the limit of the stock turbo. Since we know the 2.7 biturbo is using the same K03 turbo, I think we can safely assume that the maximum boost in stock form is about 7 or 8 psi. Chip tuners are probably raising that to around 1.0 bar, or 14.5psi, to get 310 to 325hp out of that engine. That is about the maximum those turbos are capable of.
Corey S
Wett 97 1.8tqm
'00 S4 coming soon
99 Ninja ZX-9R
Corey S
Wett 97 1.8tqm
'00 S4 coming soon
99 Ninja ZX-9R
4CE FED NOGARO
S4 (B8 Platform) Discussion
16
05-05-2011 04:44 PM
mbox
16
11-30-2005 12:35 PM
SilverS4 510
08-08-2002 06:55 AM
S4NoRice
07-21-2001 06:28 PM
