Doing some research: Those who have had waterpumps fail:
Which water pump were you running, the plastic impeller or the metal impeller?
What was the cause of the failure?
I just had my metal impeller waterpump fail due to a bad bearing after 30k. I replaced it with a plastic impeller, because it was the only option at the time. I'm weighing the advantages/disadvantages of the metal impeller waterpump.
Thanks
Thanks
I would be more interested to know who the manufacturer of the failed pump was.....
I'm fairly certain my original pump had a plastic impeller, will look at it tonight. It went to 70K without issue. My replacement pump from PureMS had a plastic impeller, made by Graf I believe.
Any chance you may have put excess axial force on the pulley / shaft when it was installed? I can't think of any other installer faults that would result in premature failure, save for perhaps dirty coolant.
Plastic, OEM
<img src="http://66.134.70.69/files/audi/streetwerke/hall%20of%20shame/water%20pump/water%20pump%202/IMG_0535.JPG">
Bearing failure
<img src="http://66.134.70.69/files/audi/streetwerke/hall%20of%20shame/water%20pump/water%20pump%202/IMG_0542.JPG">
He was very lucky
<img src="http://66.134.70.69/files/audi/streetwerke/hall%20of%20shame/water%20pump/water%20pump%202/IMG_0531.JPG">
Bearing failure
He was very lucky
RASTAMN: is IRIE
01-11-2008 09:23 AM
HIS4
15
08-22-2006 10:11 AM
