Engine/tranny pull help!
#11
2nd. Get the cat back outta the way and you can drop the dp's down a bit....
Once you get the bit into the bolts with the extension on there you need to tap it in with a hammer a bit to make sure the bit is seated all the way and won't strip the bolt at all...
#13
another question for goohead (since you're a tip also)...
what differs in tranny removal from tip to 6sp? Is there anything major that I may overlook? How does the shifter connect to the tranny itself? TIA...
pntbllfun
06-13-2021 06:34 PM
rakta *chchchanges
09-02-2008 08:33 AM
Schoei
9
08-07-2006 03:53 AM
