a few fault codes...what do you guys think...
16815. P0431
Warm Up Cat Bank 2 (below efficency) *ive cleared it and it came back, and i have celimiantors
17883.P1475
Evap Emssions Control Leak Detections Pump (LDP) Malfunction: No-Signal
16486.P0102
Mass Air Flow Circuit (Low Input)
im assuming the first code is my cat going bad, which sucks...i have piggie pipes...
the other 2 codes i have no idea what they are...
17883.P1475
16486.P0102
how much does a new maf go for??? im stage 3..i would have assumed it would be ok
or i could just clean it, would me just brushin some cloth over it work??? i guess its worth a try..
NOOOOOOO, do not brush it!!
if you brush the sensor its done!!
get some MAF spray cleaner at an autozone or so.
Firts try to make sure the maf is plugged in right and tight.
are you a 2001.5 m box? did you have to rewire the maf? if so try to check the wiring also.
good luck.
good luck.
yeah im an 01.5 the maf is wired fine...i guess ill just try cleaning the maf.
and for the celimiantors...i need a different size really??? why...what about the LDP...does anyone have one laying around..
pattersom
08-04-2006 09:10 AM
EVIL-AUDI@Audizine
VAG-COM Discussion
08-12-2004 04:35 AM
