HELP!!! b5 s4 abs, ecs, cel, lights on after doing darin intake mod.
Has anybody had an issue after doing the darin intake mod? After reinstalling mine after drilling small holes, my abs and ecs (light with the exclamation, triangle and circle) and my cel light is on too. I am currently throwing code p1425 but cant relate it to anything. I dont know what it means. Any help would be nice and if not does anyone have a vag-com in the mount vernon, wa area? Thanks!!!
P1425 is related to the evap purge solenoid valve.Im pretty sure you had to take it off to remove your air box.It sits just right above the air box its has a hose going to it and a hose coming out on the other side. Make sure the connector is on.Other than that pull codes and go from there.
QUOTE=jordonalvarado;24215623]Has anybody had an issue after doing the darin intake mod? After reinstalling mine after drilling small holes, my abs and ecs (light with the exclamation, triangle and circle) and my cel light is on too. I am currently throwing code p1425 but cant relate it to anything. I dont know what it means. Any help would be nice and if not does anyone have a vag-com in the mount vernon, wa area? Thanks!!![/QUOTE]
The only thing I took off the intake box was disconnected the 4 plugs on top of the box, i will check right now though to make sure that what your talking about is connected. Why would that throw my abs code? Is it because im getting too much air into my abs vaccum solenoid?
JMS-Four
01-30-2010 07:42 PM
