Help with hesitation and turbos. - AudiWorld Forums
Old 07-27-2014, 06:09 PM   #1
Default Help with hesitation and turbos.
Advice on boost leak, hesitation and possible turbo lady.
2000 stage 2 175k. Last weekend I pulled away from a light briskly I would say 2/3 throttle. The car started hesitating badly so I pulled over and turned the car off. When I restarted the hesitation was gone but the right turbo was noticeably louder when boosting. I drove home and parked the car . This weekend I pressure tested the intake and no leaks were detected, I pulled the intercooler hoses and the left side had no more than a few drops of oil and the right side was bone dry. I have not put the pressure tester on the turbo inlet yet to check for leaks down there. I took the car on a test drive today and the right turbo is definitely still louder but boost and power seems normal at full throttle. The hesitation is back it occurs at tip in for 1-2 seconds but then the engine smooth's out.
No check engine light but I did pull 2 codes
17521 o2 sensor that has been there since last winter
16622 manifold pressure/ boost pressure sensor g31 signal too high
Any advice on my next things to check is much appreciated.
More info to help.
APR bibipe
Spider hose is 3 years old with approx. 20k on it.
MTM stage 2 chip
original ko3's
6 speed
Does not use oil
buch434 is offline   Reply With Quote
Old 08-03-2014, 12:22 PM   #2
New boost sensor took care ok the hesitation. If I unplug the n75 sensor the turbo drill sound is gone ,it' just makes the normal spooling sound. Could that be because it's producing so little boost when unplugged ?
Thread Thread Starter Forum Replies Last Post
Audi A4 AUDI 19" S-Line Wheels for sale WillSav Parts For Sale 1 03-19-2016 04:44 PM
Thinking of 3.0 Q5 TDI acryan7377 Q5/SQ5 MKI (8R) Discussion 20 10-04-2015 08:02 AM
only 317 torque in the rs5? markN1689 Audi A5 / S5 / RS5 Coupe & Cabrio (B8) 7 10-01-2015 08:07 PM
05 3.2 tranny issues fixmya6 A6 / S6 (C6 Platform) Discussion 4 10-01-2015 02:00 PM
mutiple short to grounds problem solved-please read. jamile222 A6 / S6 (C5 Platform) Discussion 2 09-29-2015 11:22 AM
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
