Help need Opinions
01 is cheaper, gets better gas mileage and is a lot more fun to tune if you wrench on it yourself.
04,05 is a lot more money but since it's newer it should have few items to replace from a maintenance standpoint.
Just depends. Do you like to modify cars-then get the 01. If you like to just make a monthly payment and drive get the 04.
Anyway that's my 2 cents.
The 01 S4 is cheap to buy up front but after a while the maintenance costs will catch up with you if you do not do some of the work yourself and treat the car right. But personally I prefer the 01 because of the many modding/tuning options and I think it looks better than the 04-05.
I'm not on the S4-rums much, but this should help:
https://www.audiworld.com/forums/sho...php?p=13709595
Should tell you basically everything you need to know.
Classic!
The B6 S4 is not a reliable car! read up on it...timing chain guide/tensioner wear that will eventually require an engine pull to fix else engine is destroyed. About a $5K job or more, depending on who does it. And the higher the miles the more at risk...
esspee
41
12-05-2008 12:17 PM
nadrealista
19
05-13-2006 05:30 PM
Eaweg
07-05-2002 08:27 AM
