how many qts of oil for the 2.7?
It was simple.
<ul><li><a href="http://search.audiworld.com/index.mhtml?q=oil%20change%20quarts&wf=022210& amp;m=all&cat=010206&dt=range&db=01/01/1999&de=06/04/2004">http://search.audiworld.com/index.mhtml?q=oil%20change%20quarts&wf=022210& am
AudiWorld Expert
"oil quarts" turns up...
Displaying documents 1-20 of total 227 found.
1. Burned 2 quarts oil in 5K miles! [2]
I have added 2 quarts of oil in the last 5K miles on my new 2000 S4. Any similar observations? I haven't noticed any oil leaking. Is this usual for the break in period?...
https://forums.audiworld.com/s4/msgs/44203.phtml (text/html) Tue, 07 Mar 2000 08:07:28 GMT, 296 bytes
Audiworld > Forums > S4 / RS4
2. I've got an A4 2.8, but I burned oil at about the same rate until . . . [2]
I did some hard driving at high rpms. On the highway in several gears up to redline and stayed there for several minutes. Even "normal" driving I stayed in the 4-5k range. I love the sound of the engine up there. I did some redline runs in the past, but...
https://forums.audiworld.com/s4/msgs/44612.phtml (text/html) Wed, 08 Mar 2000 20:15:41 GMT, 711 bytes
3. docs weight reduction is worth like 50 quarts of oil [2]
https://forums.audiworld.com/s4/msgs/1637852.phtml (text/html) Fri, 07 May 2004 12:56:17 GMT, 162 bytes
4. 7 quarts of oil? [2]
I called the dealer to see how much Mobil 1 to bring with me for my 5000 mile service, and they said to have 7 quarts, as it uses a little over 6 quarts. I checked the manual, and I couldn't find an oil capacity spec. I recall my previous car (85 SAAB)...
https://forums.audiworld.com/s4/msgs/519726.phtml (text/html) Tue, 16 Oct 2001 07:52:56 GMT, 472 bytes
5. Does anybody know really know how many quarts of oil our engines take, the [2]
owners manual has 6.3 quarts and I used 7 quarts and I know how to read the dip stick. 7 quarts brings it to the bar....
https://forums.audiworld.com/s4/msgs/1243511.phtml (text/html) Mon, 12 May 2003 06:01:45 GMT, 289 bytes
6. Oil: 8 quarts? [2]
I took my car in for an oil change and brought 8 quarts of Mobile 1. It was my impression that the car took 6.3 quarts, but I brought 8 because I wasn't sure. When I picked my car up, all 8 were gone. Did they really use 8 or did they keep my extra 1 an...
https://forums.audiworld.com/s4/msgs/824582.phtml (text/html) Fri, 24 May 2002 07:37:39 GMT, 465 bytes
7. smithtown audi sucks!!!! Those mother f@#*&% put 9 quarts of oil in my S4!.... [2]
I changed the oil in my car for the first time yesterday since my 30K service. After I removed the undertray I was surprised to find lots of oil blow-by near the oil pan and the bottom of the chassis. I opened up the drain plug and emptied into a oil ca...
https://forums.audiworld.com/s4/msgs/1243058.phtml (text/html) Sun, 11 May 2003 12:37:09 GMT, 1048 bytes
8. Also, the S4 takes 6.3 quarts of oil....not 6 quarts [2]
Unless your pump leaves a lot behind....
https://forums.audiworld.com/s4/msgs/94129.phtml (text/html) Mon, 10 Jul 2000 07:42:04 GMT, 186 bytes
9. <b><font color="red">6.9</font></b> quarts of oil in my S4?... [2]
I've been changing the oil in my S4 and putting in <b><font color="red">6.9</font></b> quarts because the majority on this board say this is the amount needed according to a service bulletin put out by Audi. I called the local Audi dealer and they told me that 6.3 is the required amou...
https://forums.audiworld.com/s4/msgs/620859.phtml (text/html) Fri, 28 Dec 2001 10:43:57 GMT, 542 bytes
10. #1, if you change the filter, the car takes <b><font color="red">6.9</font></b> quarts of oil [2]
so if you put :just over 6 quarts" you were low to start. #2 - check your oil often. In the first 10-15K miles, cars tend to consume more oil....
https://forums.audiworld.com/s4/msgs/817898.phtml (text/html) Mon, 20 May 2002 09:56:24 GMT, 303 bytes
11. Just out of curiosity, but where did people come up with this car taking <b><font color="red">6.9</font></b> quarts of oil? [2]
My manual says maximum of 6.3 quarts with a new filter? Have the oil requirements changed between build's?...
https://forums.audiworld.com/s4/msgs/1014301.phtml (text/html) Wed, 30 Oct 2002 16:30:31 GMT, 295 bytes
12. My S4 holds 11 quarts of oil???!!! [2]
I dropped off the S4 with two cases of M1 0w40. When I picked it up there was only one quart left over. I went back in and asked the service rep where the rest of the oil was. He said he'd check in the service area. I asked for a rag to check the level...
https://forums.audiworld.com/s4/msgs/1386356.phtml (text/html) Wed, 10 Sep 2003 19:27:12 GMT, 740 bytes
13. Re: Burned 2 quarts oil in 5K miles! [2]
Another subject that "bugs" me--break-in. I drag raced my car @900miles the first weekend I had it. Drove it up and the rpm band right away [not too quickly for first 500miles], changed to Mobile 1 at 1000miles and road raced it at 1800 miles [a total o...
https://forums.audiworld.com/s4/msgs/44335.phtml (text/html) Tue, 07 Mar 2000 17:52:08 GMT, 679 bytes
14. rhetorical question: how many quarts of oil (syn) do you bring in for an oil change at the dealer? [2]
https://forums.audiworld.com/s4/msgs/147295.phtml (text/html) Fri, 29 Sep 2000 11:38:23 GMT, 197 bytes
15. how many quarts of oil is need for an oil change? thanx. [2]
https://forums.audiworld.com/s4/msgs/506477.phtml (text/html) Sat, 06 Oct 2001 06:38:57 GMT, 152 bytes
16. How many quarts of oil needed for full oil change? [2]
https://forums.audiworld.com/s4/msgs/922610.phtml (text/html) Wed, 14 Aug 2002 12:25:05 GMT, 148 bytes
17. Do I Still need 7 quarts of oil if I just plan on changing the oil and not the filter?? [2]
thanks...
https://forums.audiworld.com/s4/msgs/1250745.phtml (text/html) Sat, 17 May 2003 08:54:04 GMT, 190 bytes
18. First oil change...I can't believe that this engine takes almost 8 quarts of oil!! [2]
https://forums.audiworld.com/s4/msgs/652241.phtml (text/html) Tue, 22 Jan 2002 06:44:49 GMT, 179 bytes
19. Oil change... 7 quarts of oil was added instead of the 6.3... Any harm (more) [2]
After the oil change I have noticed that there of been a couple of oil spots under the car.. I am hoping that it is because of the excuse oil through a overflow hole or something.. Before the oil change the underside of the car was dry (no signs of a oi...
https://forums.audiworld.com/s4/msgs/1378811.phtml (text/html) Thu, 04 Sep 2003 05:47:30 GMT, 453 bytes
20. How many quarts of oil does a 2002 s4 take? [2]
I got an oil change yesterday and the receipt said 7 quarts....
https://forums.audiworld.com/s4/msgs/1656067.phtml (text/html) Thu, 27 May 2004 05:14:38 GMT, 200 bytes
thanks...
