Huge Misfires during idle, Cylinders 1-3. B1S1 No activity DTC...Is O2 the culprit?
Seems to drive ok when the engine has load. When the car is at idle, Cylinders 1-3 will misfire like crazy. I have already ruled out the ICM (Ignition control modules) as I purchased a brand new one and did the swap and it did not switch banks. Is the O2 sensor the culprit? Please help. Thanks in advance.
Also, i hear backfires at times when driving...
wow, backfires! Do you have a vag? What codes are you throwing? Did you have any work done to the car lately?
Backfires tell me timing which point to cam-adjusters and associated wiring for bank 1. The plug wires all share a common ground as well for bank 1.
Below are the DTC's:
5 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16685 - Cylinder 1: Misfire Detected
P0301 - 35-00 - -
16687 - Cylinder 3: Misfire Detected
P0303 - 35-00 - -
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 35-00 - -
16686 - Cylinder 2: Misfire Detected
P0302 - 35-00 - -
Was doing some research last night and it is also possible that I have a plugged up Cat? I also heard some backfire when i was driving around yesterday as well. What do you think?
5 Faults Found:
P0300 - 35-00 - -
P0301 - 35-00 - -
P0303 - 35-00 - -
P0134 - 35-00 - -
P0302 - 35-00 - -
Lamda sensor no activity is very strange... sounds electrical. I would ohm out your wiring from the POS for bank 1 to each Coil pack connector to make sure you have good continuity. Shake the wires while you do this.
What did you do the car recently?
I'm thinking the backpressure from the exhaust would make the O2 sensor give false readings maybe? I did not do anything to the car recently other than get new tires. It just up and out of nowhere started misfiring like crazy on my drive home one day.
internecine
05-05-2011 05:40 PM
Onebad S4
03-12-2008 03:32 PM
