k sport coilovers.. does anyone know anything about these, 36 way adjustable ???
very cheap in price ..(probably in quality as well )... anyone???
Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 36 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs. The dampening adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Camber adjustability is included on pillow ball top mounts that allow it for the ability to adjust camber from the actual coilover, instead of a separate camber kit.
Most applications utilize an adjustable lower mount, which means you adjust height without losing suspension travel like some other coilover designs do. With the mounts and most pieces of the coilover being designed for 6061 billet aluminum the kit is lightweight, durable, and rust resistant. The steel shock body is electroplated with zinc to resist rust and the elements. The valving of each set is matched to the springs installed for unmatched ride quality and reliability.
The Ksport system uses a Monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube designs the Monotube dissipates heat better, allows finer dampening adjustments, and requires more expensive design process. Aeration and cavatation are a lot less common in a Monotube design, which results in a better ride.
The Ksport Kontrol Pro Coilover kit has been designed with professional road racing in mind offering extremely high value and performance.
Key Features:
36-way adjustable dampening
Made from high quality 6061 Aluminum with T6 for increased hardness
Compression/Rebound adjustable
Adjustable spring perch for height adjustment
Adjustable body allowing maximum suspension travel
Pillow Ball Top Mount w/ adjustable camber (not available for some models)
Monotube High Pressure Design reduces oil leakage
Electroplated body for protection from corrosion and rust
One Year Limited Warranty
Spring Rates: Front 11/615, Rear 5/280
Price: $858.00
Key Features:
Price: $858.00
called the company, they advise that these units are externally adjustable, you can choose
specific spring rates as well at no addt charge, they do not come with camber adjustment plates for our cars though... anyone want to be the guinea pig ??
has anyone purchased these?! I am looking to get a set. Didnt find anything near the 858.00 pricing mentioned above. I would love to get some opinions of those that have owned a set!
first off i would like to say i dont own the k-sport CO but have read a few reviews on people who have {not for our cars mind u}. non the less they are pretty cheep and do tend to break after a short time. this also depends on how u drive the car. are u going to the track?? do u live in co, or the east coast where the roads suck? is your car daily driven? or hiway use mostly? if u answered yes to anyone of those except maybe the highway one i would prolly look into something else. either fork over the big bucks and buy quality parts for our cars or buy cheep stuff and have headacs opon headaces. 850 bucks u can have a nice set of blistens and a race spring with a little cash left over for something else.
just my .02$
just my .02$
MPower510
RS4 (B7 Platform) Discussion
9
08-14-2011 12:53 PM
Silver Streakin'
05-26-2007 12:25 AM
Damnitrudy
05-01-2005 02:30 PM
CZA4
08-06-2004 05:59 PM
