Got some dyno numbers with the K03/16's on stage 3
Old 08-05-2005, 08:03 PM
Imolavirus@BuehnEngineering's Avatar
Default Got some dyno numbers with the K03/16's on stage 3
Went to Matrix (thanks guys!!!!) and used their Mustang. I'm in a hotel right now so I'll scan the graphs later, but 340whp and 370wtq on 100 octane, 94* F, and 1.5bar tapering to about 1.3bar. I know that there is still some more hp left with some more tweaking. For reference, I think that when Matrix tuned an AWE stage 3 car this past winter they got 365?whp on 92. I have the following mods......
K03/16's with z/c, pp, and cc
RS2 injectors
83mm MAF
stock IC's
xr
mbc only with tcd
gutted stock dp's with APR v1 catback
Timing was great in the low to mid 20's with zero lemmi tweaks on timing. 02's around .86/.87 at WOT. Airflow in the high 260's/270's.
Stock IC's probably didn't help being it was in the low 90's F.
Next dyno will be on pump gas and x. Then with cams, then with some IC's and real stage 3 tuning.
Comments welcome
Old 08-05-2005, 08:08 PM
rktskicar's Avatar
Default I am interested on the numbers on PNW 92 Craptrane.
Are you planning on new IC's?
Maybe you can answer the question how much HP is dependent on temperature for S4 at given boost?
Bruce
Old 08-05-2005, 08:27 PM
jtsai's Avatar
i'll be happy w/ those numbers when hybrids go in
Old 08-05-2005, 09:12 PM
808Guy's Avatar
Any chance it will see the 1/4mi?
Old 08-05-2005, 10:21 PM
New Member
burningcoals's Avatar
Wow thats great!
Old 08-06-2005, 01:27 AM
Mike2kS4's Avatar
Default Good stuff...
Keep on tweaking and get some graphs of your boost and MAF curves so we can figure out if your taper is due to WG's opening or efficiency.
There's quite a bit more power there, for sure.
Old 08-06-2005, 06:38 AM
Member
Ochlockonee's Avatar
Good maf #s for 83mm, stock ICs and those temps.
Old 08-06-2005, 12:06 PM
Snow Trooper's Avatar
you need AWE ICs
Old 08-06-2005, 12:25 PM
Default yeah, I'm impressed that the K03 turbine side can push that
kind of airflow numbers at that hp and temp.
Old 08-06-2005, 12:27 PM
Default oh yeah, probaby next week
I don't know if i'll get to the dyno before the cams and IC's go on though
Quick Reply: Got some dyno numbers with the K03/16's on stage 3
