MAF fault code 16486, need some advice please!...
Old 09-22-2004, 10:14 AM
Member
Visti's Avatar
Default MAF fault code 16486, need some advice please!...
I just logged a 16486 Mass Air Flow Sensor (G70): Signal too Low code. I got the MAF replace under waranty about 7 months ago. The car still pulls ok, seems like a bit of hesitation but it doesnt pull as hard as it has in the past. I dont htink its in limp mode but its not as fast as it shoudl be.
The link below is a link to a psot i found. THis guy had the exact (almost word for word) problem i had. HEard a poping noise, no power, then power back on with CEL.
I have replaced my TTB with Samco. Could it have been becasue i havent cleaned my forge BPV in a while?
Thanks guys
Brian<ul><li><a href="https://forums.audiworld.com/s4/msgs/156527.phtml">https://forums.audiworld.com/s4/msgs/156527.phtml</a</li></ul>
Old 09-22-2004, 11:23 AM
Senior Member
dalix's Avatar
no reason why this MAF isn't failing as well. are you under warranty?
Old 09-22-2004, 11:39 AM
Member
Visti's Avatar
No i am not under waranty, but the MAF is. I have already got it replaced under waranty 7 months ago
Old 09-22-2004, 01:08 PM
Member
AudiS4guy - NorCal's Avatar
Default Mine blew after driving 5 miles on a new one which was replaced under warranty!! more...
unplug the Maf sensor wire and see if it smooths out...if it does then time to get a new MAF!
pentosinjunky
03-30-2008 04:51 PM
rccks96
VAG-COM Discussion
11-14-2007 11:49 AM
pattersom
08-04-2006 09:10 AM
cpayne
Audi Original "S" Cars
11-22-2005 07:22 PM
Visti
12-06-2003 08:00 AM
Quick Reply: MAF fault code 16486, need some advice please!...
