More bull**** w/ my driveshaft, need AWers wisdom to help me
#11
hard to describe but vibration, especially at highway speeds
Come to find out.. the rear joint was worn and binding as the driveshaft turned which caused the shaft to vibrate at the rubber support of the center driveshaft support bearing. IT started with a very slight vibration but steadily got worse. It's very tough to describe.
#14
are you referring to rotational slop or fore/aft direction?
The shaft and CV joint at the end should not have slack while rotating each of them by hand. My rear cv joint had just enough slop (relative to the shaft) where I could hear it click while rotating it. I could not do the same with the front cv joint.. it was very tight. IF you're referring to sliding the driveshaft fore/aft direction.. that's normal. The overall length of the driveshaft has to be slightly adjustable to accomodate slight movement of the rear diff and engine, etc.
When you install a new driveshaft the instructions say to slide it all the way forward and make a mark, then all the way to the rear and make another mark.. then move it to the center point between those two marks and tighten the center bearing mount bolts.
#18
I went with PowerTrain Industries
I called Raxles, and they didn't have any built, because they didn't have any cores returned yet.
Blauparts wanted $400 for the kit, which was a "Pre-order" item.
PowerTrain is building mine today and shipping it out today for $535. Nuff said.
