need help my 2.7t has no torque at wot
Idk what could be wrong with the car or maybe am under estimating the possible. The car goes fine when I'm at light and part throttle but if I put it to the floor it feels like the wind is all the is making me go. The traction control light stays on and I can't turn it off. Also I have codes for all 4 o2 sensors. Both cam sensors and the maf. I read 0 when I hooked up the obd2 scanner on the maf. Could that be my only problem? Or not a problem at all?
I don't think so because it wouldn't want to really perform at low throttle as well. I actually would see it more at low throttle if it was a spark plug. But those are Like the only things I haven't tried yet.
You should check them. My RS4 got loaded with the wrong brand spark plugs, and caused the world's strangest faults.. after replacement of the right ones the car runned perfectly again.
Today I changed the spark plugs and air filter, the car started having rough idle, changed the plugs
qazimo
12-10-2006 09:32 AM
Cooper993
10-01-2006 08:26 AM
93S4Q
Audi Original "S" Cars
9
01-09-2002 12:22 PM
