Need help please
Need help please
Hey guys I post a thread about an S4 I was gonna buy for $8,500 http://madison.craigslist.org/cto/1504290452.html. However, upon the final inspection i found out that there has been some oil leakage, doesn't look to bad from the naked eye however, the engine bay is tight so didn't really see where it could be coming from. The oil doesn't drip on the floor after we test drove it and left it running for about 5 mins. Let me know if you guys think this is a small issue or should I move on. Thanks
Leakage/seepage is common at the age of these cars. On the sides of the engine, probably from valve covers (easy DIY). Front is from cam seals (big job), rear from rear main seal (big job). Also maybe from lower oil pan (not too bad) or upper oil pan (big job). If it's the turbo seals that are leaking, then they may be on the way out and that's an engine pull to replace them.
If the oil isn't dripping, it's probably just seepage, but you'll still want to fix it. Post pics if you can get them.
