new k04's question
new k04's question
I just bought brand new k04's, I was just looking at them and on one side of the coldside turbine the blades look closer to the inlet on the housing then the other side. It looks like one side is just about to scrape and the other has some clearence. It also seems the turbos seem to have SLIGHT shaft play (looks like if I really wanted to I can make the blades touch each side of the housing). Is this normal? Sorry im just very paranoid I just spent a **** load of money on them.
if I listen very closely when I spin the turbine I could hear some sort of metal kind of noise while its turning. Also new is there supposed to be like scratches on the coldside inlet right next to to blades it appears that theres is only on a few certain parts.I never bought new turbos before and I just want to make sure.
Kind of confused about your first description, are you referring to the 'other side' being the other turbo in comparison?
Some shaft play is normal, since they are journal bearing turbos, when oil surrounds the bearing it will, for lack of a better term, make a 'seal' and float the shaft. As long as it's not touching the walls then you should be fine.
By other side I meant the opposite side of the coldside,on one side of the coldside the blades look closer to the inlet housing, and on the other side acroos from that side there looks to be a decent gap of clearence compared to the other. Sorry I know its confusing
http://s53.photobucket.com/albums/g6...t=000_0607.flv
thanks, so minimal side to side is normal even though it looks like it barely touching then inlet housing? I just checked them and they have no up and down shaft play so slight side to side. Another question is when I turn the wheel it spins freely but I hear a SLIGHT metal sound i dont know if it rubbing against something or that is also normal. Thanks for the replys though.
Yeah, alot of times you'll have way more than you think you should. But at 3bar of oil pressure in the jurnals you'll have a hell of alot less. As they said, it is the axial play that is bad.
audiinnj
A4 (B8 Platform) Discussion
9
12-05-2018 04:31 AM
mug23
09-27-2015 10:28 AM
bilbo6209
09-09-2015 01:28 PM
