oil lines replace or not when going stg 3
I am going K04 soon and my stock KO3 are fine and was wonerding if I should replace my Turbo oil lines or not. I have a 01.5 S4 wirtth 67K
Thanks
Thanks
I did my feed lines even though my K03s did not fail. I figured for the extra money it was worth it
especially because I have a 00 which were prone to heat issues because of the line routing. If you don't decide to get new ones at least make sure the old ones get cleaned out.
I believe it is the outlet side that was made larger in 01.5. At Honeywell (Garrett) we would
have issues with the oil not getting out of the center housing fast enough. This is because the outlet hole and line needs to be very large since the oil has to move with almost no pressure. The inlet is pressurized so it's usually not a problem.
while you're there.....we believe it's worth it
<ul><li><a href="http://4induktion.com/catalog/product_info.php?products_id=154&osCsid=aef4d5 5aa52e15e924e46286406bb985">Induktion Oil Lines</a></li></ul>
