Persistent misfire issue *please help!*
Old 02-01-2010, 08:51 AM
ThirdStrike's Avatar
Default Persistent misfire issue *please help!*
setup: rs4 oem injectors, pj-k04, apr stg 3 software, NGK BKR7EIX gapped to .026
problem: misfire on cylinder 1 only at idle. (logging vag-com groups 015 and 016 real-time) misfires on cylinder 1 hit count 100+ within 60 seconds when the car is idling. if i step on the accelerator pedal the misfire count immediately stops rising.
Logging real time under load (driving the car) misfires are 0. the car does not misfire at all going WOT through the gear and RPM ranges.
troubleshooting done so far:
-changed coil pack from (known working) bank 2 to problem cylinder
-changed spark plugs (replaced with new ones, and checked gap)
-Installed BRAND NEW ICM's and also swapped them around just to be sure
-swapped injectors from cyl 4 (known working cyl) to cylinder 1
Im stumped. I've done what I can for troubleshooting to no avail.
I cant get smog checked since my CEL comes on from this misfire issue.
any ideas?
Old 02-01-2010, 11:05 AM
complacentsee's Avatar
Have you tried lemmewinks to raise the idle by 20RPM or the adjusting additive torque offset?
Old 02-01-2010, 03:08 PM
rktskicar's Avatar
I'm with complacentsee, except bump IDLE up by 40 RPM and TQ offsett +20.
Report back.
Bruce
blackb61.8tquattro
03-10-2009 05:54 PM
erik9108
12-16-2006 09:08 AM
q20v18t
04-27-2006 07:17 AM
trailertravis13
02-17-2006 07:30 AM
dmelkin
Performance and Tuning
05-18-2003 10:41 PM
Quick Reply: Persistent misfire issue *please help!*
