PSA: Bleed your clutch
Old 05-13-2006, 06:53 PM
Mike2kS4's Avatar
Default PSA: Bleed your clutch
I noted my pedal was acting a bit funny, engaging lower than normal so I decided to bleed the clutch.
What joooo need:
Cold engine
9mm 1/4" drive DEEEEP socket
1/4" rat****
What joooo need to do:
Unbolt and move your coolant tank.
reach down in there and put your ratchet/9mm socket on the clutch slave cylinder.
Either,
A: pump up your brake bleeder with new fluid and loosen the fitting and let the fluid dribble for a while.
or
B: Have someone pump the clutch down/bleed/pump/bleed/you get the picture.
anyhow, If you haven't done it in 2yrs... I'd strongly suggest it.
Old 05-13-2006, 06:57 PM
BLK01S4's Avatar
I lack that pedal :P
Old 05-13-2006, 07:00 PM
Mike2kS4's Avatar
Default You'd better work on that man.
My other car could have had a DSG, but it wasn't good enough for me, or the wife.
FWIW, DSG is brilliant and the best ATX I have ever driven... but comes short.
Old 05-13-2006, 07:04 PM
ZephyrS4's Avatar
Default I've wondered about that. I've had the car 3 years and have never done it.
It has started to make a little groaning noise when letting it out slow.
Old 05-13-2006, 07:09 PM
Mike2kS4's Avatar
Default Just do it...
It's a bit of a reach. Make sure the Engine is cold. My impatience and high pain tolerance resulted in 2nd degree burns on my forearms, lol.
Old 05-13-2006, 07:10 PM
Banned
ModifiedA4's Avatar
Default you forgot the standard clutch bleed disclaimer...
the bleeder is plastic, and easy to break.
Old 05-13-2006, 07:15 PM
Mike2kS4's Avatar
Default Thanks for the disclaimer ;)
Mine has lasted since 1999.
Old 05-13-2006, 10:23 PM
BLK01S4's Avatar
Default I have a product just for you its called
"Hot .. Not" a sleeve that goes over your arm for doing nutty jobs like we do =] works well!
Old 05-14-2006, 06:34 AM
Member
Silver Streakin''s Avatar
Default and the other one
(if you do it from below on a lift)
if you don't move out of the way, the fluid will either end up in your arm pit or on your shoe.
Old 05-14-2006, 08:19 AM
Banned
ModifiedA4's Avatar
lol, exactly!
Quick Reply: PSA: Bleed your clutch
