PSI for K04 Turbos?
Old 02-12-2010, 05:25 PM
Renegade403's Avatar
Default PSI for K04 Turbos?
what psi should k04 turbos be running at on an '01 s4? I'm looking at an s4 with k04 turbos,unitronic tune at 12.5 psi. I was told that this is not right at all so it needs some serious work. I'm just checking to see if what i was told is actually correct?
Old 02-12-2010, 06:51 PM
1sadavant's Avatar
The psi is what ever the tune calls for...if the tune requested 12.5 psi then that is what you are going to see (highly unlikely that someone would tune for that) If the turbos are running off of oem k03 software it should hold around 8psi. Stage 3- giac around 16 psi, full blown stage 3 varies, but most spike at 23-24 and hold at 21-22. I would pressure test the car first.
Old 02-12-2010, 11:35 PM
Why is it unlikely that someone would tune for that? (sorry I'm new to audi and turbos). Also what is required in order to pressure test it?
Old 02-13-2010, 11:21 AM
1sadavant's Avatar
It is unlikely because this isn't a great deal of boost to challenge these turbos. As I said before K04's can push a lot more pressure than 12.5. Limp mode is 5psi. I believe a stock B5 RS4 is 14 psi on K04's. (only found for sale outside of USA, few exceptions exist.)
If someone is going to spend the money on a tune, they most likely will be asking for more than 12.5 psi. This is probably slower than most stage 2 k03'd cars. There is something wrong with the car! Unless this person asked for the most reliable tune out there (i.e. longest lasting life on turbos), sacrificing the potential power available. Again, this just doesn't make sense.
Who did the tune? Where is the car located? Any additional info would be appreciated in helping you decide.
Pressure Test: http://www.awe-tuning.com/media/pdf/...ure_tester.pdf
Old 02-15-2010, 10:48 PM
Justin:NorCal's Avatar
According to compressor maps 22psi spike holding 20psi is the way to go. Anything above that is out of the efficiency range.
Old 02-16-2010, 04:36 AM
thejulex's Avatar
Is it manual or tip? Tip might not handle more TQ without tranny/TC upgrade.
Nigel (no more S4)
Rocky Mountain Discussion
11-24-2007 10:30 PM
Scourge
12-30-2003 07:11 AM
its_fresh
10-28-2003 04:52 PM
Minimization
12
05-15-2002 11:09 AM
Hawaiiannights
07-18-2001 04:01 AM
Quick Reply: PSI for K04 Turbos?
