Question: oil leaking turbo
Oil Leaking
Turbos are fed engine oil for lubrication and coolant for temperature control. Generally if you pull the lower inlet hose to the inter-cooler and find a puddle of oil inside it is a good indicator that the turbo is leaking oil. They can also leak oil at the external banjo connectors. I have an automatic trans and could not envision being able to tighten the fittings however, some say with the 6 speed it is possible.
Turbos leaking oil internally are in need of replacement, sooner rather than later. Hope this helps.
Which side is leaking??I have seen valve cover gaskets leak from the corner of the seal if your look at it from under the car it might look as if the turbo is leaking but it's not. or the rear cam caps leak causing similar leak.Depends of what your symptoms are.Any noise??low boost levels??does it sound liek a fire engine??
nadrealista
12-20-2005 11:27 AM
