Questions on rebuilding block for GT kit
Going to be installing the gt28rs eliminator kit and am rebuilding block with IE rods. Some questions i have:
-What rings to use, factory?
-What is the RA for the hone so the rings seat?
-What is the recommended gap between piston and cylinder wall?
TIA
TIA
If you are keeping the stock pistons, i would just use stock rings as well. The specs you are looking for can be found in the bently manual. if you search long and hard, its out there on the internet in pdf format. maybe someone else can post a link to it.
Also, you might want to look into a Tial turbo kit. might cost a tad more when all is said and done, but i believe they make ball bearing turbos and sell the inlets and all lines etc. as well. Fitment might be better also. I have heard that the elim turbos aren't really plug and play and they are pretty pricey for what they are. I dont have any more details.
pink shrimp
18
04-07-2008 09:06 AM
e40
02-06-2008 02:35 PM
2001S4ICS
10-12-2006 11:43 AM
JoemommaS4
25
07-29-2006 09:45 PM
Steve Trac, Sec 303
13
06-30-2005 10:15 AM
