Radio going south???? (DTC's inside) and a loose clamp on the BPV
Did a scan of my car, these codes are pretty recent since I did a scan only two weeks ago.
I also had a loose BPV. One of the clamps was loose and allowed the a hose to slip up on the bPv. I was getting a wistle when I got on it in 6th gear on the highway. It would wistle but then it would go away as my RPMs rose. (hopefully the turbo lady is not planning to visit me)
I went to check codes on engine make sure everything is okay since I did feel a loss in power. The hose that was loose was the driver side bpv (lower hose) I could hear air escaping so I hope that was the faint wistle I heard. When I tightened it up and refitted the hose it piped down.
Was surprised by the scan errors for the radio since I have never seen them before...
Address 56 -------------------------------------------------------
Controller: 8D0 035 195 A
Component: Radio D00
Coding: 00115
Shop #: WSC 40626
4 Faults Found:
00850 - Control Output Active: Radio Amplifier
29-10 - Short to Ground - Intermittent
00668 - Supply Voltage Terminal 30
07-10 - Signal to Low - Intermittent
00852 - Loudspeaker(s): Front
65535 - Internal Control Module Memory Error
00-00 - -
End -------------------------------------------------------
Radio was replaced once under warrentee at 8k miles. The radio is working fine, just a random act of errors? or is my radio on its way out?
Coding: 00115
Shop #: WSC 40626
4 Faults Found:
00-00 - -
BSCA4
01-27-2004 11:25 AM
jasonc84
12-24-2003 08:17 AM
