Road Test Results
Old 09-04-1999, 02:42 PM
  #11
LCP
Guest
Posts: n/a
Yup, those are Potenza's on that S4
Old 09-04-1999, 02:51 PM
  #12
LCP
Guest
Posts: n/a
Default I believe the consensus is 17x7.5; Also, they may even have the speeds in gears wrong
Something must be wrong here. When I calculate the speeds in gears using the same gear ratios and a tire height of 24.97" (for a 225/45ZR17) I get the following numbers:
1st: 35
2nd: 65
3rd: 100
4th: 127
5th: 152
6th: 180.
These numbers are 6-7% higher than what R&T listed. That percentage error seems way too high for the tires to just be a "little" bit smaller than a computation would show (at the diameter I compute using those gear ratios, the tires on R&T's tested S4 would have to be 225/36ZR17s).
Old 09-04-1999, 02:53 PM
  #13
LCP
Guest
Posts: n/a
Hell, they even talk about birdseye maple and show pictures of carbon fiber - WHAT are they smokin?
Old 09-05-1999, 02:41 AM
  #14
ChuckH
Guest
Posts: n/a
Default 3.5" ground clearnace? THis can't be right either, can it? If...
...That's the case, nobody would even be able to go to the grocery store or anything. In the real world, where there are potholes and speed bumps, this would be a major problem. I'd need to buy a new suspension to lift my car! I suppose the lowest hanging item might be in "protected" area which resides between the left and right side wheels, but even so, it seems awefully low, taking into account all the road debris. Or do we just have giant speed bumps, rusty mufflers, landscaping rocks, and furniture on Seattle roads?
Old 09-05-1999, 09:44 AM
  #15
robfox
Guest
Posts: n/a
Default This is the same clearance from an A4 with sport package...
besides, 3.5 in. is not that low...my current jetta GLX is about 2 inches off the ground. I DO NOT scrape the ground ever, and I have terrible roads around here. I'm not saying it's a smooth ride, but I don't scrape the ground.
Old 09-05-1999, 12:51 PM
  #16
Bruce K
Guest
Posts: n/a
Re: DonP Stacks of 'em at the Superstand on Shepherd (Road and Track)... good article.
Jusforfun
Q7 MK 1 Discussion
05-26-2011 06:40 PM
Kris Hansen
05-06-2010 11:05 AM
sofTTware
TT (Mk2) Discussion
06-20-2006 08:29 PM
J.Russ
01-17-2002 08:20 AM
quickersilver
9
06-08-2000 10:09 AM
Quick Reply: Road Test Results
