RS4 Instrument Cluster into B5 S4
Old 08-04-2008, 09:49 AM
New Member
chavman's Avatar
Default RS4 Instrument Cluster into B5 S4
Just fitted the above into a 2000 S4, all working fine since the re-programming except
that the speedo is reading about 20 mph higher than it should ?
Help guys :-(
Old 08-04-2008, 10:05 AM
AVANT S4 KING's Avatar
What did you set the soft coding to?
Old 08-04-2008, 11:22 AM
AudiSportB5S4's Avatar
how much did it run you if you dont mind me asking? i was thinking about it...
Old 08-06-2008, 01:07 PM
New Member
chavman's Avatar
Default Re: What did you set the soft coding to?
I need to check with the guy who coded it for me, what should it have been set to ?
Old 08-06-2008, 01:09 PM
New Member
chavman's Avatar
Default Re: how much did it run you if you dont mind me asking? i was thinking about it...
$500 bucks used
Looks great - keys need to be coded to the dash,
had a few epc light probs but resolved those.
Just the speedo issue outstanding right now.
Old 08-07-2008, 06:57 AM
Roque's Avatar
Default I've been searching forever. Where did you find it?
Also since it was used, were you able to re-program the mileage by someone skilled in this art?
Old 08-17-2008, 11:33 AM
New Member
chavman's Avatar
Default Re: RS4 Instrument Cluster into B5 S4
Any ideas guys :-( ?
Old 08-17-2008, 04:42 PM
Roque's Avatar
No sorry. Where did you find the cluster? german ebay?
Old 08-23-2008, 05:24 AM
New Member
poseidon5's Avatar
Default did you ever get this solved? mine is doing the same thing. I have searched everywhere, and can't
find a solution. please let me know.
Old 10-01-2008, 12:28 AM
New Member
chavman's Avatar
Default Re: did you ever get this solved? mine is doing the same thing.
No never got this solved, driving me crazy.
Anyone - help :-(
We are convicned it's a coding issue but open to all suggestions, I've had a new gearbox speed sensor, all part numbers of the wheel sensors are the same on S4 as rs4 but can't think of anything else. Basically the only remaining problem is the speedo is reading about 25-30 MPH higher than the car is actually moving at :-(
Has to be an answer out there..............
On my knees guys on my knees :-(
Quick Reply: RS4 Instrument Cluster into B5 S4
