S4 turns over but won't fire after catless DPs installed need help asap!!
I have just finnished putting in new catless DPs (which I will NEVER do again!) and just like the title says it won't fire. I've checked all my connections that I removed for the install and everything seems good. Anyone have any ideas? I need my car by mondee because it's my only mode of transportation. It seems like it could be electrical but not sure. Any ideas would be helpful!
Thanks
Thanks
I will triple check it, I wish I had a vag. Will a normal OBD II scanner help me find anything? My brother n law works at a cadillac dealer and he has a nice scanner. Any way a o2 sensor could be causing this? I left the two that went to the main cat out (replaced with a plug) because I will be getting it tunned soon to get that emissions CEL off. I do how ever have the front o2s in obviously.
You need to have all the sensors connected - this car is very finicky about starting up without all the electronic checks passing spec - one random sensor that is disconnected or giving out of bounds readings can cause it to fail to start.
O2 sensor will not cause a no-start condition. Your car will run without ANY O2 sensors connected. Retrace your steps and double check anything you touched for the install. (I'm thinking vac lines or sensors near the back of the engine bay that you might have touched from the topside.) A vag-com/VCDS would save a lot of time here....
JMS-Four
Pacific Northwest Discussion
04-03-2006 09:12 AM
2low4snow
03-06-2004 07:25 AM
US RS4 ;-)
11-09-2003 06:31 PM
hondakiller
10-31-2003 01:59 PM
sissupr
05-26-2002 01:21 AM
