S4 wheels
Guest
Posts: n/a
Sorry, potential fitment problem...
Your A4 has an offset of 45mm, exactly the same as the S4's. With the additional width of the S4's wheels and the same offset, the S4 rims would stick out beyond the fender. At minimum, your tires will be right under the fender and thus potential rubbing problems.
Guest
Posts: n/a
No, exactly the opposite....
If you use a 17 x 7.5 wheel with +45mm offset on the A4, you will actually run the risk of rubbing the upper control arm WAY before you get close to the fender. On the A4, going from the stock 45mm offset wheel to an inch wider 17" wheel, you have to lower the offset to 35mm to maintain clearance between the tire and the upper control arm.
Trust me on this one.
Actually, come to think of it, 225/45/17's on the 7.5" wide S4 wheels might just barely make it. I'm willing to bet that you'll have a couple millimeters of clearance from the control arm in front, but you will probably be just touching the one in the rear.
If you put 225/50/16 tires on your stock 16 x 7 wheels, you will see the same thing. Can barely fit the tip of a woman's pinky in between the tire and the control arm in front, and forget about it in the rear. Less than 3mm clearance.
Corey S
Corey S
Guest
Posts: n/a
OTOH, they might fit...
if there's enough room to clear the upper control arm, which I think is more likely to rub than the fender.
The S4 wheels are only 0.5" wider, so it just might fit an A4 if there is an extra 0.25" (6mm) or so clearance. I guess we'll find out soon (after the S4s are delivered).
Jim
Jim
