Stupid ? where should i support tranny when installing DTS? use block of wood? or just jack?
Support the front of the transmission with a jack per AWE's instructions. Link inside
And yes, use a block of wood to distribute the load if you're not using a transmission jack with a wide head.<ul><li><a href="http://www.awe-tuning.com/media/pdf/DTS_install.pdf">Click here</a></li></ul>
Subframe can hang,
Hell, you have to force it even further down when taking the trans out.
As for support, use jack stand in line with where the mounts bolt to the trans. This is per AWE's instructions as well:<ul><li><a href="http://www.awe-tuning.com/media/pdf/DTS_install.pdf">AWE DTS Install</a></li></ul>
ImolaRocket
11-08-2003 05:15 AM
ZephyrS4
10-20-2003 08:34 AM
P. Bauer
12-08-2001 07:29 PM
