Symptoms of bad mounts... trying to diagnose some issues
#11
billdapart, thanks for the write-up. I hope you don't mind if I grab your text for my "guide"?
Jon, the snub mount is located between the motor and the radiator, near the bottom and just off the center towards the passenger side of the car. It is just a big rubber thing mounted on a ****. Its job is to dampen the forward motion of the motor. The most common replacement is made by APR - this is just a doughnut shaped piece of harder plastic that replaces the "squishier" stock mount. I think you can get it for under $50.
#12
Center support bearing
Hard to see anything unfortunately. The mounts do occassionally show signs of fluid leaking out when they fail.
I doubt the knocking is a problem with the mounts. Even a bad mount won't let the engine or drivetrain move around enough to cause knocking. Most likely you have something else that is loose.
Idk just an idea could be wrong.
ddg=shinebox racing
20
09-30-2005 01:49 PM
Mike Desi
Audi Original "S" Cars
17
02-11-2005 12:46 PM
Hidshadows
08-04-2003 11:29 AM
