Tasty SR GT goodness
After browbeating FedEx to make another delivery attempt after they went to the wrong address, I got these today.
If I'm not feeling too lazy, I might even try an install this weekend. I was being optimistic so I stopped by the dealer on the way home from work and picked up a couple pinch bolts plus nuts. Also got the piston top nut but there appears to be some new ones included with the GTs.
Anything else I need (other than tools) or anything I should replace while I have it apart?<ul><li><a href="http://www.abode.com/s4/DSC_0014.jpg">Vogtland SR GT</a></li></ul>
Congratulations!
<center><img src="http://pictureposter.audiworld.com/57154/img_9066.jpg"></center><p>Check your upper spring mounts - replaced what you need to when you have it all apart...trust me on this.
Also, make sure it all goes back together as it should - with that brass washer in the right place.
Katman
13
12-07-2007 05:46 PM
Kriminal
22
01-20-2007 01:24 AM
hoTTub
08-07-2001 11:29 AM
