Is there a procedure for deleting the afterrun coolant pump?
I think mine is leaking and I would rather bypass it than replace. I found the replace write-up, is there one for bypassing it?
I have an 01.5 6MT. Do I need to remove the manifold to get to it?
Personally I wouldn't bypass it. It's on there for a reason, you've never seen it run because it's located under the intake manifold and is REALLY quiet when it starts running after shut-down. I would just buy a new one and replace it instead of deleting it when considering the purpose it serves.
But if it's leaking I'd seriously do one thing or the other soon, because when it inevitably fails, which it will it's gonna be a hot mess and you'll be $hit outa luck..... Trust me on that, mine completely split in 2 and dumped every last drop of coolant in the car all over the pavement when mine failed (between autocross runs @ Waterfest this past summer..... use your imagination to calculate the ridiculous amount of F bombs I dropped at the time).
Yeh, I decided not to delete. I got a good deal on a pump and sensor, now I just need to suck it up and tackle the job. Unfortunately the temps around here refuse to go above freezing.
clinton c
03-01-2007 05:48 AM
UR-Idiot Savant-S6
Audi Original "S" Cars
05-25-2006 09:23 AM
BaysideRS4
03-19-2004 12:00 PM
