TIP tranny pull help!
As stated in an earlier post, I am about 90% ready to yank my engine/tranny. I only have to unbolt both sets of mounts and disconnect the tranny (shifter and cooler lines). The problem is, I can't locate the tip shifter linkage or the cooler lines! I was told that they are both located at the drivers side front of the tranny, just above the pan...but I cannot see them, or I am blind...any help or nudges in the right direction would be much appreciated.
TIA
TIA
Follow the cooler lines back from the drivers side intercooler (trans cooler is mounted to it)
Then follow the shifter cable from the body tub(shifter) to the trans.
If you still can't find them then you are blind.
Smarty39
03-11-2008 09:33 AM
jaybquick--Jason@JHM
09-06-2005 08:17 AM
