Took my door lock pump apart. Pretty obvious what the problem was...
Old 11-15-2004, 07:10 PM
Rest In Peace
O.W. Kenobi's Avatar
Default Took my door lock pump apart. Pretty obvious what the problem was...
See my <a href="https://forums.audiworld.com/s4/msgs/1817011.phtml">earlier thread</a> from today to see what the symptoms were. I VAGged the central lock system and found 01367 - central locking pump runtime exceeded (likely leak).
So, I located the pump, hit the remote a few times, and confirmed that it still had power (could hear the mechanical sounds trying to do something). Checked some of the visible hoses for leaks, but didn't find any. So, I pulled the pump out and decided to take a peek inside.
Popped off the cream colored top, pryed up the circuit board, removed the three screws holding the cylinder thingy together, and removed the top layer. Here's what I found:
<img src="http://pictureposter.audiworld.com/20137/door_lock_pump_1.jpg">
See all those broken pieces inside of the outer ring? Doesn't look right... Dumped it all out, and look at all of the pieces:
<img src="http://pictureposter.audiworld.com/20137/door_lock_pump_3.jpg">
Some kind of residue is all over my hands now - seems like it might be graphite? Here's the bottom plate:
<img src="http://pictureposter.audiworld.com/20137/door_lock_pump_2.jpg">
So, if I could find a way to replace the thing that broke from the center of the two plates and the outer ring, I should be in business. Any ideas? The wear patterns on the plates seem to indicate that this thing is supposed to spin around inside. Maybe the friction somehow generates the vacuum? I don't even know what this thing was supposed to look like when new.
I have a feeling that I'm going to get stuck buying a new part, though...
Old 11-15-2004, 07:20 PM
RKA
AudiWorld Uber User
RKA's Avatar
Default LOL!
Funny how this works...you look at it, it's so simple, but where the hell are you gonna find a piece that you can substitute. Your brain says "I'm not paying $500 just because of one tiny little broken bit"...and a week later, you're spending $500. Call some of the places in my parts thread, and see if they can get it for less.<ul><li><a href="https://forums.audiworld.com/a4/msgs/1960796.phtml">https://forums.audiworld.com/a4/msgs/1960796.phtml</a</li></ul>
Old 11-15-2004, 07:25 PM
AJN334's Avatar
Are you still under warrenty? I just had mine replaced for free about 2 weeks ago.
Old 11-15-2004, 07:32 PM
DON2.0T's Avatar
same problem here but fixed
Old 11-15-2004, 07:37 PM
Rest In Peace
200 miles ago...
Old 11-15-2004, 07:39 PM
Rest In Peace
Default I pieced together all of the broken bits, and they form a disc...
with four rectangular plates radiating out from center. I think the disc is plastic, and the four rectangular plates are what is rubbing on the top/bottom plates. I tried putting it back together without the broken disc in there, but that didn't do any good.
Old 11-15-2004, 07:50 PM
New Member
Big Blue Machine4's Avatar
This post should be nominated for the most boring/useless post of the year.
Old 11-15-2004, 09:09 PM
reefer_bob's Avatar
Try the junk yards?
Old 11-15-2004, 09:26 PM
ATH
Elder Member
ATH's Avatar
Maybe put the pieces back together, take it to a plastic shop, have them machine a new piece?
Old 11-16-2004, 03:31 AM
RKA
AudiWorld Uber User
RKA's Avatar
Default Wow! OWK...if you end up finding the part...can you get some extras?
This failure is pretty common on older A4's, and will eventually be pretty common here. Great link TipSter!!!
Quick Reply: Took my door lock pump apart. Pretty obvious what the problem was...
