torque converter removal?
Old 03-05-2011, 06:13 AM
dimitris1453's Avatar
Default torque converter removal?
hi anyone can help as far remove torque converter from 2.7t engine-tranny any tips for install new one
and do i buy the audi oem or rebuilt this one or buy one from some online stores?
got my engine out i think i need rear seal oil is everywhere...
thanks dimitris
Old 03-06-2011, 06:03 AM
complacentsee's Avatar
Get a 24mm socket to turn the crank. You need a T55 torx to remove the torque converter from the flex plate. There is a small inspection hole on the bottom of the engine. Rotate engine until you see a torx and remove it, repeat twice more.
Old 03-09-2011, 07:25 AM
ok i did thanks..
any tips as far put new one on or geting a rebuild one?
as far put in do i nstall it on engine side or keep it in tranny and then bolt it when i put engine in place?
Old 03-09-2011, 09:01 AM
Originally Posted by dimitris1453
ok i did thanks..
You must install it onto the transmission, and properly seat it first. There is a spec for this.
Basically you place it on, and rotate and keep pushing in, eventually it will bottom out with allt he splines properly engauged. If you do not do this correctly, the fluid pump will be crushed.
AdamP
04-16-2017 12:13 PM
twv5004
08-19-2011 06:32 PM
goohead
01-23-2008 11:05 AM
Gotpancit
01-02-2007 06:07 PM
peterklos
10-16-2006 06:54 AM
Quick Reply: torque converter removal?
